Apparently if the pressure switch for the power steering goes, it revs up higher for no reason. Back to normal idle :)
Good info to know! You should add it to the Wiki in case anyone else has a problem with it.
yeah, good lookin out yo.
Well, typically it shouldn't be a problem. Only happens if your cheap and do your own alignment in a hurry, where you only make sure the tires are parallel to each other, and disregard the position of the steering wheel.
