Hey I'm new to the site. I just purchased a 97 GL last night for a couple hundred bucks. There's an issue with the transmission and I was curious if some of the experts on here could pinpoint the problem. When you drive it in regular drive (not overdrive) it shifts fine and has no issues. When you drive it in overdrive it does fine until you stop, when you go to take off again from a complete stop it acts as if it is in neutral and you have to put it in reverse then back into overdrive for it to drive... Then when you stop again you have to do that all over again. I've done a little research and it seems like this is probably going to be a sensor... Any idea which one? Thanks in advance!
