1 - 11 of 11 Posts
· Registered
ok i got some new relays and harness for my new xenon bulbs, no they didnt come with instructions, there is what they look like, if anyone has any idea shhooot!!!!!!! ok two harness along with a single one, looks like it would plug into a stock harness for power, there is two relays that pop in their correct spot, and each harness has a neg wire to ground, Im lost I have no headlights and I need them for tomorrow, someone please help!!!
· Premium Member
That one is easy.
· Premium Member
BTW, where did you order your harness from? I saw a couple folks on eBay selling them cheap, but they looked like they used Chinese relays.
The one seller was located in Taiwan.
I ended up biting the bullet and getting the more expensive ones b/c they used Bosch or Tyco (Potter & Brumfield) relays exclusively.
· Premium Member
You mean fabulous?
· Premium Member
Got my harness wired in last night. It definitely makes a huge difference. I was running the SilverStars with the stock wiring for a couple months. That was a slight upgrade from the stock bulbs, but mostly in the color, not the intensity (IMHO.) The harness really makes a difference. I wired in one side and left the other side stock. The upgraded low beam was as bright as the stock high beam. Wish I had a camera to document it, but both sides are in now and I'm loving it! I got my harness kit from SUVlights.com. Their products are extremely high quality, IMO. I think there is a delay on all the harness kits b/c they are relocating their shop this week.
· Premium Member
Originally posted by spridget@Jan 26 2004, 06:53 PM
I have the SUVlights.com kit also. HUGE difference. Every Gen 3 Taurus should have this "fix".
Do you have Daytime Running Lights? I noticed today that when they are on, it causes the relays to click on/off at a very high frequency (b/c of the reduced input voltage) and I think that would shorten the life of the relays. It doesn't cause the beam to flicker or pulsate, but I still think it may be taxing to the relays. I'm going to pull the DRL fuse until I am sure about this.
*Edit* Follow-up... I just got off the phone with Jay at SUVlights. He said it sounds to him like our DRL circuits run at a "pulsating" lower voltage, rather than a constant lower voltage. Looks like I'll have to keep the DRLs disabled.
1 - 11 of 11 Posts
