hi, i have a 98 merc sable... its got the 3.0 vulcan, and the ax4n transmission, the other day when i was driving i could hear a slight noice but i was really quite and then as i got onto a higher speed road and started to pick up speed it got loader and loader, i quickly pulled over and then gave it some gas and it didnt move, i put the car into park and let off the brake and it started to roll back (was heading up an escarpment) so i put the ebrake on and called caa. now my question is, i was thinking it was maybe the transmission blew, but i was told that park is a pin or somthing and that if the transmission blows it should still lock into place, keeping the car from rolling. so im not sure if it could be a blown transmission, or and axle, or what ever connects the 2.... do front wheel drive cars have drive shafts??? any ideas or help would be awsome.... the car also makes a loud whineing noice when put into park from any gear,
Cake monster
Snapped parking pawl, perhaps? Either way, you'll be in for some expensive repair work.
yea... iv priced some transmissions and i can get a used one from the scrap yard tested and everythign for 150 cnd or i can get a rebuilt one for 200 - 250 cnd but i wanna make sure its the transmission first and not somthing else , like if it was an axle or what ever it has instead of a drive shaft then it would roll backwards when in park... but probalay wouldnt make the whining when put into park... fml i may just find a parts car for 300 and switch the whole front end
^^^^^ +1
Snapped half shaft or half shaft somehow pulled out of tranny due to CV or tripod joint failure.
