bought a sho the other day driving around and all the sudden the tach drops off and get a check engine and starts chuging then push the clutch in no chug i figure cause its in gear sooo confused i think its got to be a crankshaft position sensor or something with a tach sending unit help!!!engine runs strong im confused engine still runs when tach drops ... then tach magically comes back and car runs fine!!? :huh:
ignition module already replaced ummm whats crossover tank???
the old one is in the trunk
ill check and see if its loose or something or corroded connections
any other suggestions im open im really confused
