1 - 14 of 14 Posts
my horn on my 2000 mercury sable dont work the fuses and relay it good but idk where the connectors to clean are nor the horn is please help
Iirc, down below and in back of driver headlight sit the high and low note horns? On 99s, they were located similarly, but on each side (driver and pass.).
There's one on each side on my '96 LX.
You might get lucky cleaning elec. conn., but often the only fix is to replace the horn(s) which are readily available at parts stores. Remember, you have a hi and lo note horn. You might check owners manual first for horn fuse and relay location and ensure they are good.
Turn steering wheel all the way to the right. Remove front half of plastic wheel well liner and jack up driver front of the car. Horn(s) should be visible in wheel well towards the front of the car. Unplug and unbolt.
Discussion Starter · #13 ·
I found the reason the wires were cut the is a green and a black in the black in the same group and two blacks in the same where does the two blacks go
Splice cut wires back together using butt connectors and/or elec. tape. Then simply slide on the spade connectors on each horn.
1 - 14 of 14 Posts
