I have a 2000 Sable LS My issue is with the Aux power port under the lighter :dunno: . The lighter port will power my GPS, Sirius Radio...etc but the Aux port seems to have no juice ? :angryfire: Can anyone help ? :notworthy:
Thanks
Checked the fuses? Is the wiring firmly seated into the power port behind it?
does your ashtray light work? all three are on the same circuit and share a plug behind the ashtray. in fact the ash tray light and the cig lighter share the same color wires i would say check to make sure the plug is tight and the wires are not damaged. also if you are getting power the plug behind the power point but it is not working i would sugest replacing the component, although not common they do go bad on occasion
