1 - 2 of 2 Posts
If anyone can help me, I am attempting to wire a bazooka bass tube to my 2004 taurus sel wagon. The wiring diagram I looked at on this site is incorrect. If anyone can tell me which wires are for the battery and accessory (antenna), you would save me tons of time.
Spend my 02¢ wisely...
The antenna power wire is dark bluish with a pink stripe. It's grouped with 2 other wires that go to a plug for the power antenna on the fender well from the RCU.
As for the power wire, I would STRONGLY recommend running a dedicated power line to the battery. The factory 12 volt wire to the RCU isn't big enough to support much current, probably 20 AWG at the most. You'd probably just blow the fuse anyway.
1 - 2 of 2 Posts
