Hi! I'm brand new to this group, and in desperate need of guidance. Have a '90 3.0 6-cyl. Engine starts up and runs fine until warm. Once engine reaches about the "O" in NORMAL on the temp guage, coming off the gas results in the engine just shutting off. In trying to analyze the symptoms I discovered the following: Will run at idle speed, no load (idling at curb) for 1 hour +. But...if I advance the throttle and then release it back to idle, the engine shuts off. This basically approximates the conditions I encounter when driving. If I run the heater on high while driving, I can extend the time it takes before shutdown - I assume because the heater is drawing off the engine heat. Obviously there is something which is shutting down the engine when warm, but I've no clue what it could be. Also, after the engine shuts off, it will not restart until it has cooled to below the bracketed "NORMAL" range on the temp gauge. If it means anything, I recently replaced oil and filter, fuel filter and flushed and refilled radiator. Any guidance, direction or ideas will be greatly appreciated. Thanx in advance.
