:huh:
okay peeps i need some advice, the sable alway's leaked power steering fluid, then the hose just came out and the pump went bad.
that was about 7-8 month's ago.
okay my dad got the pump from auto zone, and ever since it make's this groaning moaning noise.
and still leak's fluid.
i was gonna wait till i'm able to walk again to take car of it for her.
then yesterday, it was just leaking like a faucite.
when ever it did leak i lil' it would leak on to the cat.
but i looled under, and you could see the fluid leaking behind the engine on the pass. side.
he keep's putting it off, i really can't do anything till i'm walking.
i know the noise is from air in the system, but then again ford pump's make this noise so it seem's normal, but not like this.
so does anyone know if thier is a line around that side i tried to look above ,b ut the coil and a/c is in the way.
plus should the pump be replaced?
