1 - 9 of 9 Posts
Guys I need some help finding a coolant hose for my Sable, I have been to Napa and Rock Auto as well as searching the net but to no avail. I need the coolant hose assembly that connects on a 24v motor the steel pipe near the front exhaust manifold to the thermostat, to the coolant crossover tube and with out looking at the car now I cant remember where the third major hose goes. The assemble, at least on my car, used a plastic oddly shaped Y to connect all these different spots witch is what failed. Any one have any advice or part number? I have not tried the stealership yet.
Thanks!
My knowledge? stops @ the 99 tec. Might try searching a thread by firespirit on this issue. Am thinking she had a prob. finding same hose?
Search "goodyear hoses" or "dayco hoses" generally gives a pic and part#. Then you can search w a part num to be sure its right. Could even get an oe# and cross it
I found the thread by firespirit. Its: Duratec Problems, Help? It sounds as if that hose is dealer only. Ford part#8a521. Good luck.
I would check all of the local parts stores first, as that hose assy. is pricey @ ford. Ive had luck @ finding bizarre hoses @ adv auto and oreilly. Good luck.
I found all hoses I needed for my 91 3.8 at Pep Boyz.....
Check out these two sites...if you haven't already...they both have illustrations...Fast Parts Network will often located the part if you drop them an email...and sometimes I find parts on the Motorcraft site even when the dealer parts counter doesn't...good luck
FastPartsNetwork
Motorcraft
1 - 9 of 9 Posts
