Allright here we go i have a 93 taurus w/ 3.0 v6 ( vulcan ) i had the timing chain cover replaced because a couple of bolts broke off in it. Any way since I got it back from the shop the oil light stays on constantly when the motor gets hot, and it sounds like a bunch of angry midgets with hammers under my hood from 2000 rpm's and up, plus when the car is in drive if you turn the wheel the motor stalls out. This problem is very annoying I've had the motor apart 3 times trying to fix it to no avail pleas some one give me some insight into this ! thanks in andvance :)
Sounds like it is out of time. You need to take the timing cover off and make sure everything is lined up ok.
Sounds like the motor is out of time, period!! :eek:
My guess is that you've got other issues, like a spun rod or main bearing, if you're getting knocking and oil pressure lights. Sorry meng. :(
