Please help I need to get to work or get fired if can't make it.
I posted a earlier thread on replacement of 03 taurus ignition actuator. Was informed probably could find my answer in past threads. By the way thanks for suggestion jag 1959. I don't have time or money right now to replace my steering column. Can someone tell me how to operate the switch manually? Does the switch kick back so as not to keep kicking in the starter? Your input would be helpful, because I seriously need to get to work.
I don't think you can. PcM needs to communicate with the key successfully to get spark.
If the switch will turn ON the ignition, that's all you need. You can then run the wires for a remote starter button to the starter, and start the car using the button.
