Help. My 1997 3.0L lit a P0420 code. 152,000 miles and the engine runs fantastic, except for a transitory higher idle when fully warmed up (1,100 rpm), I'll address my attempts to fix that later.
Mainly, I just want the CEL off. Here's what I've done. 1) I ran DuraLube Catalytic Cleaner through the fuel system twice. Both times the CEL went off in less than 30 miles, then came right back on within a couple hundred miles. 2) I removed the Bank 1, Post Cat O2 sensor and installed two Spark Plug Defouler fittings to get the nose of that O2 sensor out of the exhaust stream. The CEL came back on in less than 100 miles. Note: I did NOT replace the O2 sensor, since it seems to be doing its job. My assumption is the original cat is not performing well, thus tripping the sensor and CEL.
Next: since the engine runs great, I assume the bank 1 pre cat sensor is doing its job with the fuel/air trim, true? Should I now just replace the post Cat sensor, and leave the Defouler fittings in place? Or, replace both bank 1 O2 sensors, pre and post cat?
Lastly, I read that a defective engine coolant temperature sensor, or even a defective EGR valve could be throwing the P0420 code...true or false?
Regarding my transitory high idle when engine is up to temperature...I replaced the idle air control valve, the EGR pressure valve, and EGR vacuum solenoid control valve, PCV valve. The test I did on the EGR valve itself indicated it was working, so I did not replace that.
So, what to do next?
