1 - 2 of 2 Posts
I have a 1997 taurus GL Vulcan.
What size socket is needed for the bolts holding the egr valve to the upper intake manifold? Also, what size wrench is needed to remove the pipe going from the EGR valve to the exhaust manifold? Last question, does anyone know how to take the power steering pump and bracket off? There is one bolt left and Haynes says its behind the belt tensioner bracket, but there is no clearance, do i have to take the tensioner off? If so, how?
G
I think it's 10 or 11 mm on the EGR stuff, can't remember offhand.
To get ot the last bolt on the PS pump bracket, you need to remove the tensioner. It's a Torx socket, T45.
Doing head gaskets?
1 - 2 of 2 Posts
