J
jason8225
·Guest
I was trying to install install my diablo chip and I can't get my car to start - took the chip out... car still won't start!!! HELP!
Is the connector on the EEC on right? Is it on tight? Did you disconnect the battery before you disconnected/reconnected the EEC? That could be a bad thing. ESD can cause you some problems too. I work with routers and switches all day and I always wear a static strap whenever I am working with electronics. I hope you didn't run into an ESD issue.Originally posted by jason8225@May 5 2004, 05:24 PM
I was trying to install install my diablo chip and I can't get my car to start - took the chip out... car still won't start!!! HELP!![]()
Is the connector on the EEC on right? Is it on tight? Did you disconnect the battery before you disconnected/reconnected the EEC? That could be a bad thing. ESD can cause you some problems too. I work with routers and switches all day and I always wear a static strap whenever I am working with electronics. I hope you didn't run into an ESD issue.Originally posted by NateNBeckie+May 5 2004, 06:30 PM--><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (NateNBeckie @ May 5 2004, 06:30 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-jason8225@May 5 2004, 05:24 PM
Yeah... I took all the Cisco courses, too and have my CCNA.Originally posted by 97vulcan@May 6 2004, 09:05 PM
Electro Static Discharge. I took CISCO in High School. 1 and 2 only. Going back this fall to MATC for the rest of the course.Thought u all would like to know. lol
Adam
