I am hoping to get some insight and help about this re occuring problem i am having.
There is this heater resistor under neath the dash of my taurus that control that fan speeds for the heater and I am continuously burning it out and stuck with the highest speed or no heat at all.
I've replaced this resistor about 3 times for the year. I thought it might have been the coolant and had a extensive flush in December 2010 but i still am burning it out.
Any ideas or suggestions on how to prevent this?
Have you noticed any wetness under the carpet in the passenger floor area. The first thing that came to mind when I read your post was of this bulletin I had seen talking about water leaking into the blower case and passenger floor area. The bulletin says for 2001-2004 vehicles...but I can't imagine why your 2000 wouldn't have the same issue being the same body style and such. Here is a link to the bulletin...you can decide for yourself if this has anything to do with your problem or nothing at all.
http://content.chiltonsonline.com/T...2x80DtfYovhGRB43cQsURKGJXphh3wA26JkjlxmrCdQ==
Check the amp draw of the blower motor to see if it is too high. I THINK on high it should draw around 22 Amps, and on low about 4.5 Amps, but dont quote me on these (too lazy to look them up at 7:20 AM). Excessive amp draw will fry resistors. If draw is excessive, replace blower motor.
:werd:
Sounds to me like the blower motor is drawing excessive current. My vote is to replace the blower motor and install a new resistor.
