I would like to pass some info regarding this hose.
I was smelling antifreeze for a couple of weeks but I did not see a leak anywhere. The smell got stronger and after close further inspection I found a leak at the plastic T-connection of a heather hose to engine block. I will give the " tech name and numbers next" but I believe is the best name to explain this hose. It connects to the upper heater core connection to left side of the engine ( you standing in front of it) and the other connects the right side of the engine to the lower heater core connection. There is a hose connecting these two in a "H" pattern.
I tried the junkyard but unfortunately one of the endings is aluminum and it was in terrible shape pretty much in every car I pulled if off. I tried several autoparts but they did not have as " a unit".
The numbers on the car are 0749-5206 CIP and 0889-5207 CIP for left and right ( do not recall which is which) hoses and for the one across is F7DH8548 AB.
Dealer had a diffiult time finding it as a " unit" so he desired to reserch it and call me back. He found the number to be F7DZ-8548-AA - RACK TUBE AS. PRICE $ 118.82 (FORD DEALER)
Now let me explain the "unit" issue. The two side hoses are connected to the one going across a plastic "T" on one side and a aluminum "T" on the other side. These hoses are "glue" to the "T's", therefore making the 3
hoses a unit.
Because of the importance of this hose, going "short cut" is just looking for future trouble, unless is for a short or temporary repair. Junkyard is not recommended.
I hope this can be of any help.
Lucky.
What year/engine?
