1 - 2 of 2 Posts
I have a 2004 SEL with auto climate control. The car was wrecked in2010 and the wiring harness was replaced. Since then the heater AC. And radio turn off and on. YOU can be using the AC and hot air will start coming out
.we replaced the dashboard controls. No help. Any ideas?
I'm not sure on the 04.. but is the blend door controlled via motor or vacuum?
check for a leaking vacuum hose or possible bad blend door motor.. could be fuse too??
1 - 2 of 2 Posts
