1 - 1 of 1 Posts
Hi, ive been reading around to see what people say about their heated mirrors. From what ive read, they should heat up enough to melt ice. My mirrors (which are certainly suppose to be heated) produce absolutely no heat at all. I cant feel them getting even the slightest bit warm.
Today i tried a few things to figure out what could be wrong. The rear window defrost works fine. I looked at the fuse just to make sure (i know the rear window and the mirrors are both on the same fuse). The fuse is also fine. I popped off the mirrors and took a reading with a multimeter at the 2 connectors right on the mirror. It read exactly 14volts when the defrost was turned on, for both mirrors. So i know for certain the circuit that leads to the mirrors is working. But what else could be the problem? Can i take the mirror apart and check the circuitry inside (it looks like its all glued together). Any help would be appreciated, thanks.
1 - 1 of 1 Posts
