Hey guys. Like the title says that's the issue . Light on the dash for rear defrost lights up but I've got nothing from either the mirrors or defrost? It's an 03 SEL. I checked fuse 12 , 10amp it was good. Is there a relay ? If so would the light on dash still light If the relay was bad? Seems odd id lose both at once. But I guess I lost both power wi dow n door lock on one door same time too so maybe not so odd. Thanks a lot.
The circuit has multiple fuses and relays. In addition to fuse 12 there's another 10A and IIRC a 40A in the cabin fuse box as well as a 40-50A in the underhood BJB ans a relay in the relay center. You can consult your owners manual for the exact locations
I've checked all the fuses n replaced the relay under the dash. Nothing. Hear the click from the relay n the light comes in the dash switch. If the defrost grid was bad the mirrors would still work right? I'm stuck. I can't imagine all 3 failing individually
