Is it possible to add heated mirriors to my'97 Taurus..how hard is it to hook them up..do I need 12v feed? also can I get them to match (royal blue metallic)? any help would be appreciated!!
Pop off your door panel. Some cars are prewired for the power mirrors w/heat. You can tell by having 5 wires (3 colored, 2 black) coming out of the female door connector.
Make sure you check out our topic finder feature (click the link at the top). Sean T. wrote up a great article on swapping the mirror assembly from one housing to the other, so you can retain your old housings but have the new heated feature.
And if you don't you can run new wires to the mirrors, one goes to the rear defog switch power, and one run to a ground.
