OK, someone else on here has to have some of these problems. As you all know, I have a 1993 Vulcan. My problem lies in that my engine ALWAYS runs hot. It has been around 35 degrees here, and I have the heat going up to the N, and then the electric fan comes on, pushes it back down to O, and then repeats. In the summer, I even have it stall sometimes from the heat, and then won't restart for a while. I have a normal radiator, unclogged as far as debris, fairly new coolant, a big tranny cooler, and regular non-ethanol gas (the ethanol seems to make it worse). How can I fix this? I don't feel safe taking it on trips because of this, and its a pain in the a**.
P.S. - I have followed the Ford Service Bulliten and replaced the TFI sensor. It is mounted on the throttle body, and was known to go out quickly because of excessive heat, causing problems. I now have the new and improved version, so thats not it.
P.P.S. - Also have a new fuel pump from Ford, factory type, so I doubt that is it either.
Thanks all!
Thanks all!
