okay. i posted this once before...but i think i may have been wrong about the problem. so here we go:
my daytime running lights started flickering one night...not off and on, but bright and dim really fast. now they're permanently dim. also, the bright light indicator on the dashboard quit working when the running lamps went out. i don't know if its conencted, but the problem started the same night.
the bright lights on the outside of the car work, but the indicator inside doesn't. also, i adjusted the headlights recently because they were really dim, but it didn't help. i go down the highway with my brights on and no one else notices.
could it be bulbs? i had a brake light go out recently and when i checked the bulb, both filaments were fine, but there were three little bumps on the bottom inside of the bulb, right above the connector. two of the little bumps were black, but the rest of the bulb was fine. even the tail light worked fine, just no brake light.
my question is could the headlights be doing the same thing?
