One eveing i went to the store and when i came out i found out my headlights don't work. I put in 55 watt hids with the relay hanress in previously. I figures it might be a grounding issue but when i unplugged the factory harness to check the harness i wasn't getting a ground. The ground which is the center wire and its a constant 12v and also the low beam wire is a constant 12v even the car off. does anyone have a suggestion? Iam thinking maybe the GEM module shorted out.
