Hello all I have a 2013 Ford Taurus that’s been having a passenger side headlight issues over the last two days that Iv been attempting to track down. So the other day I noticed my headlight started to flicker on the passenger side only before completely turning off and turning back on after a short period of time. I then stopped by the auto store to purchase a new bulb which didn’t fix the issue. After serval attempts to repair and check all fuses i believe I finally located the issue. The harness inside of the headlight was corroded and the found wire from the connector to the headlight bulb was burned out. So now that i figured it out I can’t seem to locate the harness i need to replace the connector and wires. The part number is PBT-GF33 which is can’t locate anywhere and it’s not a Ford Part. Can anyone please point me in the right direction Iv been working on this for days now. I’ll post photos of the harness below. Any help would be greatly appreciated.
note: the driver side light works normally
