1 - 14 of 14 Posts
So I ordered one of those 100 watt harnesses from suvlights.com since everyone said it makes a difference, I havn't gotten it yet however. But I understand I can run 100 Watt bulbs in them (I learned the hard way it will melt a regular harness), but can the light fixtures handle the 100 watt bulbs. Also, how do I aim the lights properly on a Gen 3, I went by the manual and they seem all jacked up, so I looked in my haynes manual, and well its the same thing. What's the trick.
just park the car on flat ground, and turn the adjustment screws until the bubbles on the levels are centered. I have done it on my G3 and never had any trouble.
me too. i just aimed mine two days ago. use the bubble...line it up. remember to line it left to right before you do it top to bottom.
lenses shouldn't melt...but they could. others will be able to provide more insight.
good luck.
yeah i need that too. i did a google search and couldn't find anything. i guess my only hope is here, and if anyone her eknows...they aren't tellin :(
I would not recommend using the 100w bulbs even with the heavy duty harness. They create so much heat that you may melt something else. 55/65w bulbs will show a noticeably brighter light though.
The adjustment screw isn't phillips, it's a torx screw with a little pillar in the center of it. You need a special torx driver to adjust them, or you can attempt it with a leatherman or pair of locking pliers. Make sure that when you go to do it, you're on really level ground. Go to Home Depot and buy a cheap level to check the grade of the area before you do it.
Also, one of my bubbles is gone...what can I do?
JR
JR
Take the car to an empty parking lot... or the far end of the WalMart parking lot after dark. Adjust the lights until they look even. Check both high and low beams. You don't want to adjust the low beams to high and blind oncomming drivers. Also, the light should aim a tiny bit to the right. Or aim the right headlight a tiny bit right and the left headlight should aim straight.
1 - 14 of 14 Posts
