To answer the original question, and possibly make us look more intelligent after that fine display of imaging, here's my answer about the head gaskets, along with some diagnostic advice.
First the diagnostics:
-check the plug after letting the car run for about 30 seconds. Is it wet with coolant? If yes, it's a defenite bad head gasket.
-check the compression on all cylinders. PSI should be around 150-160, however you're more interested in the change amongst the cylinders. They should all be within 10% of each other.
-does the coolant reservoir bubble when the car's running? Does it puke fluid out when capped? If so, it's another sign of head gasket failure.
-Does the car overheat, or use up coolant? Another classic sign.
For the replacement, it's fairly simple, and doable by a backyard mechanic with a decent set of tools. A torque wrench is required, however those can be rented at Autozone if you don't have one.
I'll go over some basic things you'll defenitely want to do, however the Haynes manual covers the replacement pretty well. There's simply too much info to type it all out here, you'd be best off to spend the $15 or so and get the manual.
-After removing the heads, take them to your local machine shop and have them pressure checked for cracks or leaks. Have them resurfaced too. Around here, I can get all that done for around $130. It's money well spent, you don't want to have to do this job twice.
-Do not re-use the old head bolts. They are torque to yield, and stretch upon installation. Re-using them will result in improper torquing, and eventually failure. They're only about $30 for 16 of them.
-If the car is going to sit for any length of time, drain the oil and refill with fresh oil. Ethelyne Glycol (the major ingredient in anti freeze) will erode the surface of the rod bearings and eventually cause failure of those as well. No need to create more work!
Now is also a good time to paint your intake, etc. while you have it off. It'll kill some time while waiting for the heads to be done at the machine shop.
If you need anything else, ask away or PM me.
