1 - 9 of 9 Posts
Ok gang,
I have a 2000 Duratec Sable. Lately I've been having a hard starting issue in the morning. It takes many cranks and I have to pump the accelerator to get it started. Once started, it runs fine. No codes.
I have changed the fuel filter, air filter, and plugs. Any suggestions?
I want to nip this in the bud before winter and the wet season comes.
Gene in Baltimore
2000 duratec is COP... does this always occur?
Try cycling key to on position 2-3 times to see if that helps prior cranking. If it does, pull vac. hose off fuel pressure regulator(fpr) & see if hose end is fuel-soaked indicating diaphragm inside is shot. Fuel(pressure) might be leaking off & back to tank.
You can also remove the cap on the schrader valve test port on the fuel rail & shielding eyes with shop rag, depress valve stem with a key or sm. screwdriver to check for spray on cold eng. in the morning. If none, fuel(pressure) has prob. leaked off overnight. Poss. time for a new fpr.
Hard starting 2006
My 2006 had the same problem. The engine would turn over but not start as if starving for fuel. I tried the pumping of the accelerator and the switching the ignition off and on. Today was the worst. I started hearing a clicking noise when I would attempt to start the car. While the clicking was happening, the instrument guages would tremble. When the car wouldn't start at all, I raised the hood and noticed corrosion on the battery posts. I cleaned it off and had the battery tested at AUTOZONE. It tested bad. I replaced the battery and the starting problem is gone!
Discussion Starter · #8 ·
Replaced the battery last year. I did try the key cycling trick but it didn't seem to help the situation.
Yesterday, in 80 deg/low humidity weather, I started the car after sitting for 8 hrs. Had to pump the gas as usual. Engine started but then immediately shut down. Turned the key again and motor fired right up, had no other problems.
This morning ( 65 deg/low humidity ) engine started fine (had to pump gas as usual) and I had no issues driving to work.
I'm beginning to think IAC or DFPE.
1 - 9 of 9 Posts
