incase u cant remember the specs of the sub from old site,
it is as follows:
FS-30HZ
QTS-.728
Qes-.923
Qms-11.128
Vas-142L
Xmax 1way-11.1mm
efficiency-86.3db
SD-.0491m
RE-3.2
Nominal Imp-Dual4ohm
PowerRMS-500W
Mountdepth-152mm
holediameter-300mm
going with a sealed box. i want the best spl possible.
what should my cuts be on the box?
it is as follows:
FS-30HZ
QTS-.728
Qes-.923
Qms-11.128
Vas-142L
Xmax 1way-11.1mm
efficiency-86.3db
SD-.0491m
RE-3.2
PowerRMS-500W
Mountdepth-152mm
holediameter-300mm
