1 - 20 of 29 Posts
As stated in the title, i was wondering if there were any cheap easy upgrades i could do under the hood just to make my 97 taurus GL "feel" a bit sportier.
First of all, before spending money on mods, make sure everything is in good running order. You don't want to spend all your money on mods and then the car breaks down. Get a TRUSTED mechanic to go over EVERYTHING. Make sure everything is sound.
Then you want clean out the crap. The engine is old. Over time gunk builds up which hurts efficiency and reduces performance. Use a product called Seafoam. Research it online before using it to ensure you use it properly. It will clean out the gunk in your fuel system and valve train. You won't gain hp, but you will recover some lost hp.
Well the basics are pretty cheap and easy. You don't gain much power, but you will get a deeper sound, and a little better response.
Trash the current air box/filter set up and go with more open pipe and a high flow cone air filter.
If you don't have to pass emissions tests, then tear out all the existing exhaust piping and main catalytic converter and go with 2-1/2 inch straight pipe. And add a high flowing muffler. Like a Magnaflow, Flowmaster or Thrush.
Upgrade your plugs, wires and ignition coil.
Those are the 3 basic mods most people to to start. If you do all 3 you may add up to 10hp, but you will feel a little better throttle response and will get a deeper growl to it. It will drone at idle, but that is a pretty cool sound to me.
You could do all 3 of those for about a thousand bucks total.
Then maybe look to your electrical. Upgrade your alternator. I got a new 120 amp one. Not a lot more juice, but a little more. Get a new, performance battery. I went with an Optima Yellow Top. And upgrade your big 3 wires to 1 or 0 guage.
Change your thermostat to 180 degree one. A cooler engine runs better, but don't go down to low. A 160 degree is too low.
You can add the JET performance module to your ecu (onboard computer).
Run high octane gas once all this is done. I run 94 octane only.
Then the most important thing.......Regular maintenence. Do not neglect the boring maintenance stuff. That will keep things running well for a long time.
Then if you have lots of money, you can move on to more advanced performance mods.
Then maybe look to your electrical. Upgrade your alternator. I got a new 120 volt one. Not a lot more juice, but a little more. Get a new, performance battery. I went with an Optima Yellow Top. And upgrade your big 3 wires to 1 or 0 guage.
Well said.
A few additions. GL is the vulcan engine. That engine takes a LOT of work to feel 'sporty', and I know this from experience. For better plugs, get iridium. A lot of people recommend autolite, but I always use NGK, and have had zero issues.
After all that, I don't reccomend JET chips. I just hate chips. My advice is the SCT flash tuner, which is a steep $350 investment, but any changes you want to make down the road are significantly cheaper. You can (get a respected, experienced tuner) to lean that bad boy out and advance the timing. These engines are way too conservative from the factory.
When all that's said and done, it'll still be slow. But the sound and the initial torque off a stop will give you the illusion of having the car get out of it's own way.
Happy modding.
The intake is already a cold air intake and if you place the cone incorrectly you can end up with a hot air intake which is bad.
Removing the silencer and adding a K&N filter will probably net the same amount.
Larger piping doesnt always help and can kill the low end especially on the Vulcan which only produces 140-150hp. 2.5" will work on the Duratec for the catback portion only. One the y-pipe we sell for the SHO we only use 2.25 for the y-pipe. Any more for N/A and you loose power.
Jet chips are junk. I would only go for SCT tuners.
High Octane wont do anything unless the car is designed for it.
Everything else was pretty good.
Agreed that the Jet chip isn't great, had one. But it is a cheap, entry level mod. Can grab a used one real cheap and just plug it in. Very cheap. Yes, a tuner set up is far better, but I not as cheap once you buy the component and pay a tuner. But yes, much better route. Even better is a stand alone EMS, like from AEM. But now that is big money.
I think the higher octane does help after having done all the bolt on mods. It does have a slightly cleaner, better burn. Agreed it doesn't do much at all if you haven't done mods, but after the bolt ons, it does help a little.
Though none of those mods do much on their own, doing all of it would result in roughly 25-30 more hp than what is being made today. :)
I have to disagree almost completely with just about everything Jimmer says regarding the actual mods. Yes, you do need to get everything back to factory specs, so cleaning it and getting a tune up is a good idea. However, the Taurus GL from that year is powered by the 3.0L Vulcan OHV V6. There are performance gaining mods, but don't expect them to be cheap. The 3.0L OHV is an expensive engine to get more power out of. A freer flowing intake will do almost nothing. It is louder than stock, which creates a perception of power. But unless you have a full shroud around the filter, you will draw in warm air, which will invariably produce LESS power than stock. Unless you do something radical like a ported head, and an aggressive cam, the stock intake is not just adequate, it is overkill. The best part is, you already have it, so in effect its free.
Next, the stock exhaust, while not ideally configured, is already the right size. The cat is free flowing enough, the same basic setup supports over 240hp in Lincoln Continentals. Yes I know they have a bigger engine, but the same sized cats. If you want, you could eliminate them, but running a larger pipe size will gain you little power, and could cost you low end torque. The best exhaust gains your can do on a 3.0L Vulcan is to run 2.25" pipe from the cat back, and use a straight through free flowing muffler. After that, it is the stock heads and valves that are the biggest restriction to flow.
Your stock plugs are already excellent, though upgrading to an Autolite or NGK Iridium won't hurt anything, and they will last longer. Most performance wires are inferior to the original Motorcraft wires. The only performance wire I can recommend is Magnacor, which is the only performance wire that meets or exceeds OEM quality. As for the coil, the stock one is very high quality, the performance aftermarket ones might deliver more juice, but tend to be less reliable. This is especially true of Accel. Performance ignition does not increase power anyway. All it does is prevent you from loosing power under high strain conditions, such as high RPM, under high compression, or when running forced induction.
Running a higher output alternator is optional at best. Unless you run an underdrive pulley setup, your stock alternator can meet more power requirements. Optima batteries are less than what they are cracked up to be, a check with their less than stellar reliability record can confirm this.
Running a JET or SCT tuner can deliver a good amount of extra power, especially if you opt for high octane tunes. They won't work miracles, but they can support other mods. They are required for aggressive mods, like larger injectors, larger MAF, aggressive cams, forced induction, etc. These are a good investment to get more power.
Running a higher octane can deliver more power with a supporting tune, however, you are still running a lower compression engine on high octane, it is a waste most of the time. I would not run higher than 91 even with a tune. To justify any higher than that, you either need to raise your compression, or run forced induction.
Stick with the stock temp thermostat. A lower temp t-stat is only good for track cars, and cars that are driven for extended time periods. For a daily driver, the factory specs are best.
Better brakes is the only realistic performance improvement mod that can be done.
That mean at the minimum better pads, newer high-quality rotors (if the old ones are scratched).
The next step would be bigger rotors/calipers than stock '97 (I am in the same boat with my '96) but, without bigger wheels than stock 15" (for that year), with better grip, that wold do nothing.
I have a dyno slip that shows 143hp & 179tq to the wheels with a vulcan. If you fab a decent 3" CAI (not WAI), you'll notice a difference. If you replace your muffler with a better-flowing (read: noisy) one, you'll notice a difference. If your plugs are worn, just changing them will show a difference. NGK iridiums come in handy because changing the rear bank is a huge pain, and I read on the internet somewhere that they produce more consistent sparks higher up in the RPM band. The internet is reliable, right?
Taking cats out will cause a no back-pressure situation at low loads & low rpm, which will take your intake charge and throw it straight out the exhaust during cam overlap. Keep your cats.
The stock vulcan exhaust is 2" for G3, and 2.25" for G4, isn't it? Both of those will support decent amounts of power until you go FI.
I've run the stock, worn out coil pack as well as an MSD pack, and they were indistinguishable. Stay away from Accel. The best wires I've come across are bosch premiums, which I can't find anymore, and NGK. Both were an upgrade from the old ones; neither was better than the other.
What else are people feeding you lies about?
Octane is just how controllable the burn is. Higher grade gasoline is better for higher performance engines because you can push it closer and closer to the limit, and it will consistently burn at the given rate, and you won't risk detonation. Cheap gas will light up if you look at it wrong. If you do go the SCT route and get your car dyno tuned when everything's said and done, you can fill up with 91 or 94 or 107 (don't actually), and you and the tuner can push the tune as far as the octane will take it. On my '97 SHO, the PCM pulls 2 or 3 degrees of spark if it senses detonation, to compromise for cheap gas. I have 6 degrees advanced timing, and I run 87 without problems. Worst case, I'm still running 3 degrees up, without pinging or detonation. I wouldn't worry about octane until you're shaving the heads and putting smaller pulleys on your supercharger (it'll happen).
Because everybody is sharing their own opinion, this is my opinion. My old engine just happened to agree with my opinions, but that doesn't mean anybody else has to.
I agree with your assessment, and if you were able to get more power using a better intake, thats great. Are you running a larger TB too though? You are also running a tuner, I don't see an intake doing much of anything unless you take a tuner and get more timing advance and other tricks to take advantage of it. I don't see why you couldn't get those same dyno numbers with just the tune and other mods, but stock intake. The stock intake is almost identical to the Duratec and SHO intake (as far as the air box and silencer is concerned), and the Duratec is 200 hp at the crank, which is probably around 150-160 hp at the wheels after losses through the trans, and the SHO would be around 190 hp at the wheels. That is for a stock setup, no mods. However, those are guestimate figures. My Duratec is 126 at the wheels, but that is not taking the elevation losses into account. From those results at my elevation, with the adjusted altitude pressure, air temperature, humidity, and other factors taken into account, what my actual power would have been to the wheels at seal level at similar temperature and humidity, my hp to the wheels is closer to 180-190 hp, not too bad for a car that has only exhaust mods, everything is is pretty much stock, including the intake. I'm not running a tune currently, though that is on the to do list.
Not trying to downplay your results in any way. A stock vulcan will only produce 145-155 hp depending on the year. By the time it gets to the wheels, that could be as little as 120-130 hp. So to get 146 at the wheels is a major accomplishment, you could be producing as much as 175 - 180 hp at the crank.
Well, Zuljin, you managed to put to contradictory statements here:
So... why bother to replace the muffler if you don't change the cams? To brag about dyno/WOT power and run like crap at stoplights?
As for octane, the resistance to detonation is not all the story. Gas has components (fractions) that evaporate quickly and fractions that are evaporating slower. On aggressive accelerations, close of WOT, the gas injected in the intake does not evaporate as easy as when you have a vacuum there, so in cylinders, only the super volatile fractions will be present, the rest are lining the walls. Burn will be lean if the PCM does not add extra fuel (fuel trims).
Higher quality gasoline has more of the volatile fractions than cheap gasoline. So, if you drive a lot in stop-and-go traffic, and you take off at stoplights like I do, you can see a benefit from better gasoline, benefit that advancing the spark will not achive.
Plus, advancing the spark, tends to "slow" down the cylinder and increase the fuel consumption, increase the stress on engine...
You didn't ask, but you were close enough that I'm going to explain anyway.
Friction is a bitch. Friction from the bearings, friction from the oil, friction from the air. An engine takes horsepower to turn, and losing some friction gains you some ponies to the ground (I say ponies because they are a fraction of a horse).
On the intake stroke, the piston going down requires power to fight against the vacuum your engine generates. Take a plastic syringe, seal it against your finger, and pull the plunger out. It gets a lot easier when you take your finger off the end, doesn't it? If you open up your intake, you're reducing the amount of power it requires to push the piston down on the intake stroke, which means less fuel is burned per hp produced (yay!) and more power is produced per throttle position, to an extent.
You have your normal limiting factors at WOT such as valve size, head design, TB, etc, which will reduce your WOT peak hp reading between intakes. This is why a CAI is so much fun when it only nets you 2-5 hp, because throttle response is sharpened, your fuel economy goes up (if you keep your driving habits the same) and you'll feel the increase in torque at part-throttle. And hear lots of noise at WOT.
And when my poor old Sable still lived, I had a 60mm TB and 70mm MAF. I have laundry lists of it all over this forum, just pm me if you want more info.
(insert my statements)
I can contradict myself all day. It's how I pass time at work.
Mufflers won't lose enough back-pressure to make you run like crap at a stoplight, while cats may. There are lots of people that've taken cats out, and their idle just gets a little choppy. "Running like crap" is an exercise of tolerance, really. You can tune for missing cats, but unless you're keeping it high in the RPM band, there's not really a point for a DD.
But back on topic; read my reply to Khan's unwarranted intake lecture, and change it for exhaust.
Despite exhaust gas being under pressure, it still needs encouragement to flow. The pressure pushes down on the piston, which takes hp from another cylinder's power stroke to push up. If you reduce that, you gain power. This is why race cars like not having back-pressure. It's a balancing act, of course, because I previously mentioned you need some back-pressure to keep the intake charge in the cylinder. I remember with my old Sable, I lost a few hundred RPM off idle when I put a free-flow muffler on. Big whoop. With less back-pressure, a vulcan would probably run like my SHO, that trips over itself until 3k (but without the power that follows).
Clear as mud?
No disrespect intended, but all of the mods I suggested fit with what the thread asked for, cheap under the hood DIY mods. All the ones listed do help as entry level mods. Only a little each, but together they make a difference as a whole and don't cost a lot.
I don't know if you are a licensed technician at a performance or race shop, but I will tell you I am not. However, there are 5 race shops that I do consult with regularly, one, Evolution Racing, is the one doing the heavy lifting for my engine. All of them, all 5 of them, confirmed that the listed mods do in fact slightly improve the performance and response in a Vulcan engine. They weren't trying to sell me the mods as I already had them done.
Even the lowly Jet chip does help a little. Granted, a tuner or, even better, a full stand alone ems would be better, but the subject of the thread was "cheap". The Jet chip does help a little bit and costs very little. It's not going to give you 10hp, but will give you a little bump up and will work even better with other mods. After all, if you pop one open, it isn't just an empty box, there is a circuit board in it that does something.
As I said, no disrespect, but I don't know your credentials, but I do know the credentials of the 5 race shops that I know and I will continue to trust their expertise. After all, their entire work day is spent making cars faster, and if they all say that those listed mods do work, I tend to believe them.
Discussion Starter · #15 ·
thanks to everyone who has suggested useful, cheap mods that i can do.
with 10hp being the most i could cheaply crank out of my engine, i think i'll just leave her be...
Probably the best bet. The mods I suggested would probably run you around 3 grand. They would give you about a 30hp gain from what you have right this minute. (a rough formula is $100 per 1hp gained/retrieved). I say that because some of the mods don't add hp, but reclaim hp you have lost over the years the car has been running, generally you lose about 1% per year. Just from gunk build up and wear & tear. You would gain a noticable increase in response time, meaning you will get more jump off the light than you do now. That would give you more of the "sportier" feel you said you want.
The problem is, it doesn't stop there. It's like a junkie always wanting more. I started off with those mods. Loved the result and wanted even more. Now, I have put over 12 grand into my ride and am in the process of rebuilding a duplicate, Vulcan engine, because I want more. I now, regularly launch harder and smoke many cars I couldn't before...BMW's, Audis, Mustangs, Chargers, etc. The list goes on.
Now I want to smoke Vettes, GT500's, Vipers, etc. I am working with 5 different race shops to build the Taurus/Vulcan engine that will do that, but I am looking at another 30 grand to get there.
I can afford to do it, so it's ok for me, but if you are penny pinching, it's probably best not to start something that will lead you to wanting more more more like I did.
And the reason I am doing it to the Vulcan engine and not just doing an engine swap is because I want to do what no one has, what so many say can't be done. Well it can be done, just going to cost me a ton of money, but, like I said, I have the money to do it. Ask yourself how much you are willing to spend. Remember, $100 per hp.
Just my opinion.
$100 per hp isn't really accurate. You can put a muffler on your car for ~$200 installed (if your shop is a rip-off like mine) A K&N filter and removing the silencer cone is the cost of the filter (~$40 on ebay), and you'll probably be happy with the results.
So for less than $300, you'll probably gain a healthy 5 or 6 hp. Beyond that, yeah, a pound of flesh for every inch gained kinda deal.
I didn't say it was accurate, I said it was a rough formula, which it is. Sure, if you go shopping for auto parts on ebay, things can be cheaper. And things can be junk too. You can also spend $400 on a muffler and gain 3 hp. It's just a rough formula. It's also better to slightly over estimate the cost of a job, than it is to under estimate it.
Wow.. I have to add my 2 cents.
all a Jet chip will do is advance timing, giving you a minute bit of HP gain, as long as you use high octane fuel. the price of the Jetchip vs. cost of fuel vs. potential HP gain doesn't add up to anything but wasted money.
the programmer mentioned would be nice, however I don't believe should be used until all mods are completed.
Iridium plugs give longevity, NOT more HP. they are 100k plugs, no HP plugs. I wouldn't really recommend an iridium plug, they aren't for every car. a regular platnum would be fine, NGK, Motorcraft or even Autlite for your Vulcan would suffice.
If you want something noticable get Pulsestar.
as for wires, motorcraft wires are made by Prestolite. they're good. Not worth the money for them. for a performance wire I'd actually look into a set of MSD or Taylor's instead.
I'd also put an MSD coil in as well at that point.
But for basic and cheap mods..
180F thermostat, it'll get you passed California smog with no problems, and the motor will run a bit cooler.
cone filter and intake tube will help as will removing the baffle in the air box.
Find the correct resistance rating for temperature at 75F and put in place if idle air temp sensor. it will trick the car computer into thinking the temp is 75F at all times.
gas pedal slack mod.. Ranger Trucks are known for this.. several Taurus's I've seen have the same issue.
Ford deliberately does this to keep the car slowed down.
follow the
gas pedal upwards. you'll see the cable attachment on top.
life the pedal UPwards till it stops. the top part of the pedal will be against the firewall. you will see maybe up to 1/2" of cable sticking out (sometimes more, sometimes less). you need to close that gap! I use cable ties and wrap them around the cable until the slack has been removed. Usually 3 small ones does the trick.
the gas pedal will now be higher than what you're used to. when you romp on the gas, you'll notice the difference.
at full WOT the butterfly plate will be full horizontil, or closer to it.
I'm not sure on the 3.0, but if it has 2 coolant hoses plugged into the throttle body, you can safely remove them and join them together with a coupler. all this does is help is ice cold weather helping the throttle body plate from freezing. I suppose if you're in a cold climate you should leave that..
but where I'm at.. it's worthless, but mandatory for smog. Go figure.
the idea is to take away the excess heat generated from the hot water flowing through it giving you a bit of cooler air going in. cooler air is more dense, which is what we want.
the cap & rotor, well not much to do with this, I use cap& rotors with brass fittings vs. steel or aluminum. they conduct a sneeze better and don't oxidize or corrode as easily.
If you're brave, get a dremel out with a grinding wheel & see if you can port out the throttle body hole. more air flow = more HP.
same with the intake manifold.. a port & polish kit is relatively cheap, probably take a couple hours to do and you'll notice a gain instantly.
Also lightening the load in the trunk helps but is minute.
proper tire inflation helps as well.
Also.. synthetic oil.. amsoil or redline IMHO is top notch.. everything else is fine too.
Quality oil fitler.. motorcraft (made by purolator so it's good anyway) is a good choice. don't get a "racing" filter, less media traps less dirt. you still need to keep the engine clean too. synthetics will help.
Also I'd add an aftermarket tranny cooler because you'll be driving faster and the temps might get to high and we all know Ford AXOD's aren't to friendly. Also a must.. bottle of Lubegard Red. (this is NOT a snake oil. it's proven to work!)
but the tranny cooler will help a lot.
If you can find an adapter.. an oil cooler sandwich adapter if you can find something to fit. cooler oil will last longer and keep the engine happier in the process.
Most of these are pretty inexpensive mods and are easy to do and will generate noticable results.
1 - 20 of 29 Posts
