My Service engine soon light came on the other day so I pulled the codes:
Code:
===PATS DTC U1147===
Code: U1147 - There is a problem with the communications link between the PATS and the PCM. Use DMM to check the communications link wiring.
Module: Passive Anti-Theft System
===END PATS DTC U1147===
===PATS DTC B1681===
Code: B1681 - PATS transceiver module signal is not received.
--Possible Causes--
	- Damaged PCM
Diagnostic Trouble Code details
PATS transceiver fault.
===END PATS DTC B1681===
===RCC DTC None===
Successfull DTC reading, no error codes found
Module: Remote Climate Control
===END RCC DTC None===
===OBDII DTC P0401-C===
Code: P0401 - EGR system insufficient flow detected
Status:
 - Confirmed - malfunction is confirmed
Module: On Board Diagnostic II
This DTC may be caused by :
Blocked vacuum hoses
DPFE sensor hoses reversed
DPFE sensor metering orifice restricted
DPFE sensor downstream hose off or plugged
Vacuum hose connecting EVR to EGR valve
Plugged or Stuck EGR valve or EVR solenoid.
Carefully inspect the vacuum hoses associated with the EGR system for signs of incorrect routing or damage.
Suspect DPFE sensor.
===END OBDII DTC P0401-C===
===OBDII DTC P1400-C===
Code: P1400 - DPFE sensor circuit low voltage detected
Status:
===END OBDII DTC P1400-C===
===PCM DTC P0401===
Module: Powertrain Control Module
Plugged Restricted or Stuck EGR valve or vent.
Suspect EVR solenoid.
Suspect PCM.
===END PCM DTC P0401===
===PCM DTC P1400===
Open Vref.
Leaking upstream pressure hose.
Shorted DPFE sensor signal circuit.
Suspect PCM.
===END PCM DTC P1400===
===IABM DTC None===
Module: Integrated Air Bag Module
===END IABM DTC None===
===GEM DTC None===
Module: Generic Electronic Module
===END GEM DTC None===
===RAP DTC B2425===
Code: B2425 - Remote Keyless Entry fault
Module: Remote Anti-Theft / Personality Module
===END RAP DTC B2425===
===ABS DTC None===
Module: Anti-Lock Brake / Traction Control Module
===END ABS DTC None===
I recently replaced the EGR valve so I will throw a DPFE sensor at it to see of that solves those codes but the security codes are what i'm concerned about. I have noticed the theft light blinking after starting the engine but since the car starts and runs fine I never thought anything of it. When I pulled the codes I googled U1147 and only found posts about no start conditions or posts with no conclusion. I want to make sure this "communication" issue won't disable the car and leave me stranded somewhere. What might be causing this issue? I do have 1 aftermarket key but have for years and never noticed this issue before, could this be the issue or would it have thrown a MIL earlier? I also noticed that one of the keyfobs only works intermittently (haven't noticed it on the other fobs, so i just figured it was a dead battery in the fob) Is this because of the B2425, any pointers on fixing this issue? Do I just need to reprogram that fob, or all the fobs? Car is a 1999 Duratec Sable
thanks -Brad
Check/clean out the "c-channel" thoroughly behind the tb gasket prior replacing the dpfe sensor. Use a slotted screwdriver/tb spray. Also clean the 3 notches at the bottom of the channel. In the upper lefthand corner of the channel is the passageway to the egr valve. That must be clean/clear too.
sorry for the late response, just spent the last week replacing a blown radiator hose.
thanks sheila, ill do that when I visit my parents next (not allowed to work on the car in my apartment parking lot, had to limp it to my sister's house to fix the radiator hose.)
any ideas about the security dtc's? or should I not be worried/will this not disable the car if it hasn't already?
About this Discussion
2 Participants
Shadow351
Full Forum Listing
