Its getting cold and my 97 vulcan has been running cooler than i thought it
should. Heats been luke warm. Flushed out the heater core for good
measure. Good flow, clean fluid when done. Hooked up the scan tool,
it been running around 135/140 temp or so. But, it seems with the heater
on, the cooling fan seems to be cycling. Now, this is heat only without
defrost so as i thought i understood it, the fan should not be forced on
like it is with the AC running. So my dilemma is, why is the darn fan running
at that cool of a temp? IF the scan tools is reading 135/140, and the CPU signals the fan on at 215 or so, why is the dam fan cycling on and off?
once in awhile it does jump up to 205/215 or so. something is obviously
intermittent. I am trying to find a CCRM to swap in, but have not got
that done yet, Any ideas?
It seems to the the fan is coming on too soon not allowing the motor to heat up when its cold. Outside are temp seems to be OK on the scan too.
