G
Guest
·I ordered these from NR Automobile Accessories through NOPI. The set includes the 3 gauges and the 2 warning light bars. They REPLACE the old faces instead of covering them like some aftermarket faces do. The only problems I found with them is the tach print is slightly offset, and the spedo does not have bold tick marks for the 5's spots. I painted the hubs of the needles flat white to match the faces and the underside red so they would stand out. To paint the underside, make sure you sand off the white paint first or it won't work. Lastly, I put some white paper in front of the 2 indicator lights in the corners so they would blend in. I think it turned out pretty well.
I need to get a decent digital camera
