What specifically is your question? I have a 2011 Taurus Limited FWD and just changed my entire suspension out. Inner/outer tie rods, control arms, control arm bushings, struts, strut bearings, stabilizer links, and basically the same for the rear. TS6034 on YouTube did a control arm replacement on a Ford 500 with essentially the same suspension with the exception of the steering. Pretty good video. If for some reason you deside to change your struts AVOID Monroe Quick Struts at all costs. Their strut bearings/bushings are absolute garbage.
