Please direct any additions/corrections to Jag1959 via PM.
Engine
3.5L Cyclone V6
Horsepower:
263 @ 6250 RPM (2008-2012)
288 @ 6500 RPM (2013-2014)
Torque:
249 lb-ft @ 4500 RPM (2008-2012)
254 lb-ft @ 4000 RPM (2013-2014)
Compression Ratio:
10.3:1 (2008-2012)
10.8:1 (2013-2014)
Oil Capacity:
5.5 Quarts (2008-2012)
6.0 Quarts (2013-2014)
Oil Weight:
5W-20
Firing Order:
1-4-2-5-3-6 (2008-2014)
Spark Plug Gap:
.052-.056 Inches (2008-2012)
.049-.053 Inches (2013-2014)
2.0L Ecoboost I4
Horsepower:
240 @ 5500 RPM (2013-2014)
Torque:
270 lb-ft @ 3000 RPM (2013-2014)
Compression Ratio:
9.3:1 (2013-2014)
Oil Capacity:
5.7 Quarts (2013-2014)
Oil Weight:
5W-30
Firing Order:
1-3-4-2 (2013-2014)
Spark Plug Gap:
.027-.031 Inches (2013-2014)
3.5L Ecoboost V6
Horsepower:
365 @ 5500 RPM (2010-2014)
Torque:
350 lb-ft @ 5000 RPM (2010-2014)
Compression Ratio:
10:1
Oil Capacity:
6.0 Quarts (2010-2014)
Oil Weight:
5W-30
Firing Order:
1-4-2-5-3-6 (2010-2014)
Spark Plug Gap:
.033-.037 Inches (2010-2014)
Transmission
6F50 (3.5 Cyclone V6)
Fluid Capacity
10 Quarts (2008-2009)
9.4 Quarts (2010-2012)
10.9 Quarts (2013-2014)
Fluid Type
Mercon V ATF (2008-2009)
Mercon LV ATF (2010-2014)
Gear Ratios
1st: 4.484
2nd: 2.872
3rd: 1.842
4th: 1.414
5th: 1.000
6th: .0742
Reverse: 2.882
Final Drive
2.77 (2008-2009 AWD, 2010-2012 SE/SEL)
3.16 (2008-2009 FWD, 2010-2012 Limted FWD, 2013-2014 FWD)
3.39 (2010-2012 Limited AWD, 2013-2014 AWD)
6F35 (2.0 Ecoboost I4)
Fluid Capacity
9.0 Quarts (2013-2014)
Fluid Type
Mercon LV ATF (2013-2014)
Gear Ratios
1st: 4.584
2nd: 2.964
3rd: 1.912
4th: 1.446
5th: 1.000
6th: .0746
Reverse: 2.88
Final Drive
3.07 (2013-2014)
6F55 (3.5 Ecoboost V6)
Fluid Capacity
10.2 Quarts (2010-2012)
11.6 Quarts (2013-2014)
Fluid Type
Gear Ratios
1st: 4.484
2nd: 2.872
3rd: 1.842
4th: 1.414
5th: 1.000
6th: .0742
Reverse: 2.88
Final Drive
2.77 (2010-2014)
3.16 (2010-2014 Performance Package)
AWD Components
Rear Differential
Fluid Capacity
2.4 Pints (2008-2014)
Fluid Type
Motorcraft SAE 80W-90 Premium Rear Axle Lubricant (2008-2014)
Power Transfer Unit
Fluid Capacity
18 Ounces (2008-2014)
Fluid Type
Motorcraft SAE 75W-140 Synthetic Rear Axle Lubricant (2008-2014)
Cooling System
Coolant Capacity
11.1 Quarts (2008-2012, 2013-2014 3.5L Cyclone V6)
11.4 Quarts (2013-2014 3.5L Ecoboost V6)
11.6 Quarts (2013-2014 2.0L Ecoboost I4)
Coolant Type
Motorcraft Premium Gold Engine Coolant (2008-2009)
Motorcraft Specialty Orange Engine Coolant (2010-2012 [Check Cap], 2013-2014)
Motorcraft Specialty Green Engine Coolant (2010-2012 [Check Cap])
Fuel System
Tank Capacity
19 Gallons (2010-2014)
20 Gallons (2008-2009 Non-PZEV FWD)
20.5 Gallons (2008-2009 PZEV FWD, 2008-2009 AWD)
Power Steering Fluid
Fluid Type
Mercon V ATF (2008-2009, 2010-2012 [Except SHO])
Brake Fluid
Fluid Type
DOT 3 (2008-2012)
DOT 4 (2013-2014)
Engine
3.5L Cyclone V6
Horsepower:
Torque:
Compression Ratio:
10.3:1 (2008-2012)
10.8:1 (2013-2014)
Oil Capacity:
Oil Weight:
5W-20
Firing Order:
Spark Plug Gap:
2.0L Ecoboost I4
Horsepower:
Torque:
Compression Ratio:
9.3:1 (2013-2014)
Oil Capacity:
Oil Weight:
5W-30
Firing Order:
1-3-4-2 (2013-2014)
Spark Plug Gap:
3.5L Ecoboost V6
Horsepower:
Torque:
Compression Ratio:
10:1
Oil Capacity:
Oil Weight:
5W-30
Firing Order:
Spark Plug Gap:
Transmission
Fluid Capacity
Fluid Type
Gear Ratios
1st: 4.484
2nd: 2.872
3rd: 1.842
4th: 1.414
5th: 1.000
6th: .0742
Reverse: 2.882
Final Drive
Fluid Capacity
Fluid Type
Gear Ratios
1st: 4.584
2nd: 2.964
3rd: 1.912
4th: 1.446
5th: 1.000
6th: .0746
Reverse: 2.88
Final Drive
3.07 (2013-2014)
Fluid Capacity
Fluid Type
Gear Ratios
1st: 4.484
2nd: 2.872
3rd: 1.842
4th: 1.414
5th: 1.000
6th: .0742
Reverse: 2.88
Final Drive
2.77 (2010-2014)
AWD Components
Rear Differential
Fluid Capacity
Fluid Type
Power Transfer Unit
Fluid Capacity
Fluid Type
Cooling System
Coolant Capacity
Coolant Type
Fuel System
Tank Capacity
Fluid Type
Brake Fluid
Fluid Type
DOT 3 (2008-2012)
DOT 4 (2013-2014)
