I have a question to anyone who has flushed a Gen 3 Vulcan about there results.
Has anyone solved or reduced an overheating problem on a Gen 3 after the flush?
I have been seeing some limited information about "Hot Spots" in a head and
that it can cause flash boiling. I assume these hot spots are from crud build up
internally. (rust internally?)
So, my question is in a gen 3 Vulcan with good heads and good head gaskets,
has the coolant flushing actually reduced the coolant temperature?
My 97 with a 96 motor has new radiator, new water pump, new themostat,
had a non chemical flush at motor change and does not have brown coolant
now. It does not puke coolant, but it runs up at the top of normal
and sometimes slightly over. I also swapped the two temp senders
with no change in symptoms. It has heat hot enough to cook eggs.
The fans only seem to kick on right at the top mark of normal.
The fan resistor is hot so i assume the low speed is ok.
Unfortunately, i don't have a OBD2 scanner yet that i can read live data
on the temp sender and the fan status. An recommendations on a cheap
scanner to do this?
bob
scanner to do this?
bob
