1 - 12 of 12 Posts
The cassette player in my '99 Taurus has been broken since I bought it. For some odd reason, no cassettes would fit inside it. As it turns out, the loading tray is broken. I was able to pop it back in place, but when i tried loading a cassette it just broke again. Does anyone know how to fix or replace it? And if I need to replace it, where can I find a replacement? (I already tried a junkyard)
Thanks
Thanks. Say I do find the piece; How would I remove and install it? Is there a guide on how to do it?
You just insert two special tools you can buy for a few bucks or two philps screwdrivers and pull it out. Easy. Switch wires and hoses. Ten minutes tops
Fwiw, you need 1 from a '98/'99 Taurus/Sable. '96/'97 have different elec. conn. You can buy the 2 u-shaped Ford radio removal tools at Walmart, parts stores, Amazon or Ebay for ~$5.
You will need one of these tool sets:
OTC 7575 Radio Removal Tool for Ford https://www.amazon.com/dp/B0002SRBJ8
Not sure about year compatibility, but it make sure you get the one with the same A/C / Climate controls.
However, if you have manual A/C controls you can easily put in an aftermarket system using one of these kits:
Scosche FD134030B ICP Kit DIN/ISO with Complete Harness Set for 1996-1999 Ford Taurus/Sable with Rotary Climate Controls https://www.amazon.com/dp/B000KIR8MK
And your choice of stereo.
Alternatively, if your unit is not at the point of causing a drain on your battery yet... You could do something like this and just hook up a Bluetooth or any device with the 3.5mm audio out to a channel on your radio...
Discussion Starter #11
@sheila, @gamefanatic
I’m not intending on removing the entire radio, just the little tray that loads the cassettes. But since you asked, I’ve got the automatic climate controls. Thanks for the info anyway.
Well, if you think you can fix it, you're gonna need some torx drivers. Its not hard at all though. After pulling the radio out with the special tools:
Unscrew everything from the back
Separate the front of the ICP into it's two halves (be careful, some electric pins will hold it together)
A few more screws on the inside to remove the box containing the mech
Unscrew the top cover and remove the PCB....you will find the m e c c h
Don't forget to clean and demag before reassembly
Might as well clean the temp sensor, to keep that little vent looking nice
ENJOY the A N A L O G
1 - 12 of 12 Posts
