1 - 2 of 2 Posts
· Premium Member
Its really easy to put those gauges. Remove the stock oval radio and once you remove it you will see 4 bolts and unscrew them. Take out the plastic trim. Then to your left hand you will see your Headlight switch plastic, remove it too. Once you do that you will see 2 bolts so unscrew them and you will see 2 bolts more in top of the instrument panel. When you have done with all that pull back the plastic that has the A/C vents and then you will see that everything will be easy to do now. Then remove all the bolts in there and you could take out the panel now. Hope this will help ;)
Frank.
1 - 2 of 2 Posts
