Inside or outside?
If it is inside it might be a leak near the fuel rail (that feeds the injectors) with gas fumes blown into the passenger compartment by the A/C.
Inside or outside?particularly near the driver's rear door, but all around the car.
PIc my '01. So by the date on this, 9 years old and it failed.I'd say that indicates it is not a leak in the EVAP system (that recirculates fuel vapors from the tank back to the engine). And also not a leak in the fuel filler neck (I had mine replaced because it looked so awful it seemed 10 years older than the car itself and the state inspection warned me about it).
Leak above the liquid level will set a vapor code.Could be rot on the top of the tank. Do you live in a salt zone?
You might think, but I got a small leak code when my filler neck had a hole in it. Same with a faulty gas cap.Leak above the liquid level will set a vapor code.
