1 - 9 of 9 Posts
today i was going to look for a job
and i got about three miles away from home and my vss (that i was thinking was fine) started acting up again i stoped at the gas station and it was working i left the gas station and i noticed it was shifting not right. so pulled over and let it sit for a few minutes. then i decided to take off and head to my destination still nothing but then it jumped to 10 mph then back to zero she did that again then it was 20 - 30 mph then to the speed i was going then it started hooping down 40 - 30 30 - 20 - 10 10 - 0. so i did the same thing pulled over and let it sit then she was ok i have noticed some thing when i go around 60ish she acts up if i stay around town she is fine so i am thinking it could be the vss sensor who agrees with me? or could i be wrong
Intermittant VSS signal to speedo, PCM, etc is a sure sign of a failing VSS. Could very well be heat related.
At least you were probably able to reach yours from the top! On the 3.8L Essex, you can only really get to it by dropping the y-pipe and jamming your hand up in there to feel around. (The smart thing would have been to drop the rear two subframe bolts, but I don't have access to a two-post lift.)
You don't need a lift to drop the subframe. 2 jackstands for the frame and ramps for the rear wheels will do nicely.
1 - 9 of 9 Posts
