1 - 2 of 2 Posts
Hi, i have a 95' taurus... the car has had some fuel pump problems for a while.. when it first started the fuel pump would constantly run so there for you would have to dissconnect the battery at night.. and such... Anyways.. i moved and the car ran fine to get it down here... but then it sat..
I one day wanted to go start the car and had to buy a battery for it..... i put the battery in .. car ran fine.. It sat again for a couple months..
I went to go start it and it started like Water was in the gas.. i finally got it running and took it for a 30-40min drive.. put new gas in it and such...
I got home with it.. Turned it off.. went to start it again and it would't go... Well i messed with it a few days later and i noticed that the fuel pump wouldn't run when i turn the key...
I bought a new fuel pump.. dropped the tank and put the new one in.. thats were i am today..
I hook the electrical connector back on it and tried to see if it would run before i even put it all back together again...
Well it is not running.. HELP ME PLEASE!
Im not a mechanic it's my girlfriends car im just trying my best to get it going.. Please help
Dustin
Sounds like the CCRM is the problem. It is where the relay is for the pump and a sticking relay is the only reason the pump would run with the key off.
1 - 2 of 2 Posts
