2001 DOHC Taurus that was sitting unstarted for around a month.
- Turns over fine but will not start.
- I have spark.
- I replaced PCM and pump relay with a/c relay - althouh I havent actually tested them.
- Cannot hear the whine of the pump starting when turning key.
- Tried banging on tank around where pump is to jar it a little.
- Inertia switch in trunk is not ...un-pressed.
Sounds like the pump to me. Any other ideas?
If it is the pump, is there a wiki, instructions with pics, etc available. NOt sure if I should try it or not.
Thank you!
Check to see if the pump has voltage during the prime cycle / cranking. Use a test light for this, not a DMM. Easiest place to check is at the inertia switch.
I have the same problem with my car. I made an access door to the fuel pump but not sure how to test voltage. I want to be sure the pump is bad.
When testing for voltage at the inertia switch make sure you test the fuel pump side and not the input power side. I had one of these go bad once.
