1 - 11 of 11 Posts
Well, after growing tired of the loud HUMMMMM and the accompanying vibration of the back seat, I felt it was time to replace my aging fuel pump. And so I did...
...with a Walbro 190LPH fuel pump!! w00t!!
I decided to go against the grain, and replace the pump through the rear seat floor pan, rather than dropping the tank, which can prove... fun. Not really tho. <_<
Now, to get through the floor, you obviously have to cut a hole.
A HOLE!??
Relax, it's not as hard as you'd think, and several before me have done the same. I used this guy's instructions, and they were dead on! Yeah!! You own Dave!! Even if you don't own your Taurus anymore
Now, in Dave's tutorial, he used a Dremel, and cautioned against deep cuts due to the close proximity of fuel lines and harnesses below the surface. However, several on SHO Forum have used a Sawzall or similar to perform this procedure. Given the close proximity...
OMG!! WTF!1
LoL... Are you insane? THere is NO room for something like that below the surface! Use a dremel and a steady hand. Anything else is just asking for trouble.
Once the new pump was in, I took a plasma cutter to a scrap hood, and cut a piece of steel 1" bigger on all sides that the piece I removed, secured it with some self tapping screws, and was good to go.
Yes, I have friends who have scrap hoods and plasma cutters lying around.
So all in all, it was a fun day.
Some things for future reference tho...
Use the dremel!
It's the only thing I know of that can cut without going below the surface of the metal, if you're careful. A sawzall is a great way to turn your Taurus or Sable into a smoldering heap.
~Hamal
G
Its a fun little project. But if you have a real steady hand, you can do like I did and use a die grinder with a 4" cutoff wheel. the only consequence was I barely knicked one of the vent lines. But overall I would suggest this method over dropping the tank any day.
Right, but I drive a Gen2 that was born and raised on New England winters, salt and all. You know the minute I take a socket to those bolts, snap!
Cutting hole in floorpan > Snapping fuel tank strap bolts.
Great Post!! Thank you.
Also... Just read you live in QUEENS. I do as well. Middle Village. I own a 1992 Taurus. 374,000 miles now. She's my TANK.
She has a few issues at the moment. It's killing me thinking that I might have to leave her soon...BUT I'M NO GOING TO. I've owned her since 74,000 miles till now. Aloy of history, and always there for me. Even during 2 of my 3 Deployments over seas,... every time I've come home after she sat for over a year...put the key in and drove off...HOOAH!
Any Idea how to get a hold of fuel supply lines from tank to engine? Or do you think I can use high pressure fuel line from tank to fuel rail? Answer or no answer, great post sir.
I did exactly the same procedure on my 01, 04 and 06 Taurus just so I could adjust the float for the sending unit to fix the annoyingly inaccurate gas gauge. I'll be dammed if I'm dropping the tank for that.
Got the idea from when I owned a 95 Chrysler Concorde that came with a removable plate in the trunk.
Forgot to mention, I used a nibbing tin snip to cut the hole and duct tape on the piece I cut out for the cover.
Cheers,
Joe
I've got a '99. Is the location of the fuel pump the same in all Taurus?. I'm asking in case I decide to do this. I've done it in a pickup truck with good success, and will probably do it to the Taurus.
Yes it is. This thread was dormant for 10 years until recently if you need further assistance please create a new thread.
1 - 11 of 11 Posts
