1 - 2 of 2 Posts
Key on engine off you should see 12V on one wire. The other is a ground specifically for that injector and switched by the PCM. If you backprobe the connector and have the engine running, setting the voltmeter on AC you should see a variable voltage with the other voltmeter lead on the pos battery post..
1 - 2 of 2 Posts
