1 - 2 of 2 Posts
Is there something I can soak these bad boys in to make sure they are clean? Have them off figure might as well ask.
Also what can I use on the intake to clean it up some?
Well, Sea Foam is used to clean it internally. I'm not sure how long you would keep it in the chemicle if you pull the injectors out.
For the UIM, you can try using throttle body cleaner. Somebody, correct me if i am wrong.
What do others think about Simple Green?
1 - 2 of 2 Posts
