I took my 2007 Taurus to a lube place and while I was there decided to replace the fuel filter. Only problem was, none of the guys that worked there could figure out how to remove it. They said one side has the typical white hairpin clip, and came right off, but the other side has some sort of a white block and they couldn't figure out how to remove it.
Anyone know what I'm talking about? :dunno:
The shop you took it too is a bunch of idiots. Both clips are the same IIRC, easy swap.
hi,
they look different on the top of the clip
(less plastic then the older clips, save $$)
should come off the same way.
on the other hand, at least they stopped the job
and were honest with you. too often somebody
keeps going and then stuff gets broken !
