You want to drive up on the ramps backwards or park your car vertical to a ditch so that your right rear tire is just before the ditch and your right rear window (the small ovalish one) is just above the ditch. Either one of those ways will give you EASY access.
The fuel filter is located under the passenger side rear door. Before you change it, start your car and let it run. As it is running, hit the emergency fuel shut off switch in the trunk. Let it putter out. Now, change your filter. Get a pan or bucket under there with you. There are 2 plastic clips that hold it on. You should have received new ones with your filter. If you did not, DO NOT proceede until you have a new set. Do not reuse old plastic stuff - lesson learned. If you have them, pull off the old ones and disconnect one line at a time. Keep your pan or bucket undere the filter during this time as fuel will spill out. WARNING - DO NOT LAY UNDER AND LOOK UP AT THE FILTER AS YOU REMOVE THE TUBES OR THE FILTER!!!! Remove your last line and drop your used filter into the bucket/pan. Install your new filter - NOTE PLEASE PAY ATTENTION TO THE FLOW ARROWS ON THE NEW FILTER - replace each line and install the new clips. Reset the fuel filter switch and start the car. It might take a couple of seconds to start back up or a couple of cranks. After that, you are set!
Enjoy.
[/quote]
I will do this within the next month, but it's a friend's car, not mine. I have an F150 V6, and have a tool that disconnects the locking spring in the fuel filter. I know I should disconnect the fuel pump fuse and run system dry but so far, I think five fuel filters, I leave truck on ramps overnite in driveway, and then crack open gas cap and proceed to loosen one side of filter. Some gas, yes, got it in my eyes once..will probably do it the correct way next time. I changed oil in 05 Taurus for gf and looked for fuel filter and did not see one. Reason is, I looked on driver's side and now know it's under rear door, passenger's side. I thank you all for such good advice. :chili:
Enjoy.
[/quote]
I do not have the fuel filter yet, Wix 33097, but not sure about these clips. I have clips on my F150 that pull down to access filter and then swing up into place when installation is complete. Is the Taurus line/filter connection different.
