For jobs I didn't have the right tools for...I just take the parts to the local mechanic and he charges the regular labor rate and warrantied his work. It had been reasonable generally, but this latest visit has me more than irritated.
I requested for the rear subframe bushings to be installed up front (and I told him I knew they looked different, but they will work AOK), new motor mounts/transaxle mount, and a new oil pan gasket since I messed that up originally. See here on the original drop slip:
http://i30.photobucket.com/albums/c325/bea.../IMG_2266-1.jpg
Want to take a gander at how many hours I was charged for all that (@ 65/hour)? Try eleven hours "labor". I have no idea if that sounds too high or low...but I'm guessing on the high side.
He called at the end of Friday to let me know that the crankshaft pulley needed replacing and it's seal was leaking oil...ok...well if it needs replacing go ahead. 3 hours labor, and billed for a new pulley (1F1Z-6A312-AA) and a new oil seal (based on part # from invoice, click). Not sure if that was a necessity but here is a high res pic of the old pulley here
What gets me is this:
1) He installed the rear subframe bushings...in the rear, and never called me to get the "OK"...cause I would have told him no. I told him the front (per the sheet above). He says its impossible they are welded in and the subframe would move around if the rears were installed (ugh :bs: )
2.) He put in 6 quarts oil when I wrote down and said 5.5 ...maybe it doesn't make a big difference, but still...second time this has happened. I provided the oil and filter, and he did not charge for that labor.
3.) Check these three sheets:
Sheet1
Sheet2
Sheet3
-->How are my front brakes at seventy percent...I just had michakaveli help me out and put them on 9/20? I call BS.
-->I also call BS on them taking the time to remove my wheels and check the rear brakes.
-->9/26 This mechanic FLUSHED the brake fluid with Mobil1 Synthetic Dot3/4 stuff...wtf how is it dirty already? I watched them change it that day while sitting outside.
I start the car to leave, put it in gear and *dinnnng* Low Coolant illuminated. OK...turned the car off, opened the coolant recovery tank and its where it should be. I call mechanic over...and then a tech comes out and says "it came on yesterday". :huh: Right...it just magically came on...coincidence? Since it's OK, he says to ignore it. I know I'll have to either replace the tank or try cleaning it out to fix that sensor...but I have the factory tank.
My thoughts are probably scattered (sorry about that) but I am really not pleased with the experience. Maybe it's just worth not going back there again...but do I raise some valid points? I feel like I got taken to the cleaners yet again just trying to do some good to the car.
I got my old parts back...see them here: http://s30.photobucket.com/albums/c325/bea...OldParts121708/ Notice the old rear SFBs look just fine...
Can't wait for my own garage someday...
Sheet1
Sheet2
Sheet3
