Anyone have this happen before what are the tell tales of this?
This is a ford product I myself got the taurus
Well anyways my mother needs help with her Cougar it was in this fall getting a new intake put on it cause it was plastic and it had cracked the intake cracked as soon and she started to leave the house so she turned around and parked it.
then it was towed to the dealer to get the intake installed 1000.00 later it was fine and ran better then ever. Then over the next month the low coolant light kept popping on and it wasn't even low? She took it too the dealer and said everything was fine they tested the antifreeze and said it was good till 40 below. Also they had added a little antifreeze? Well about the fist week in January it was -10 outside in Minnesota and thats without the windchill. She started it up with a loud whining noise from under the hood, with it running she thought it was just a belt loose. again the low coolant light is on again and it was not low I asked her if the jug was frozen but she had failed to notice. without thinking anything wrong since the car was running fine she started to drive it to work. The car didn't get any heat for the longest time she stated and then it finally stated to get warm when she got about 20 miles form the house. Then everything was fine. But the temp gauge didn't stop at the normal spot this time it continued to climb then she paniced and then went to a gas station to check it out. she opened the hood to look for something and she had said that the coolant bottle was overflowing. ANYONE with any ideas on how this happened?
